Hi, I just connected a Project DS phono stage to the inputs on my Naim Unity Atom. The sound from my record came blasting out at full volume and cannot be controlled by the app or volume control on the Atom. Any suggestions?
Is the input set to fixed volume (Av bypass)? If so, you should change it back.
Thanks Richard, that worked.
That’s a lesson learned and a test you don’t want to repeat!
Indeed trouble is there are no real instructions with the equipment except for a quick start guide. So its all trial and error
The online help and support facility may be of assistance.
