Connecting HiCap, Nac and Nap
Greetings
This is a second system for my home office, could you please tell me this is the right way to connect my HiCapDR , Naic122x and Nap150 please?
Looks OK to me.
Should be -
SNAIC5 from HiCap Socket 4 to NAC112.
SNAIC4 from any other HiCap socket to NAP150.
Collars on SNAICs should be at the Signal end.
Thank tou so much,
I just powered on and it rocks !
BTW do you have any link for the reference manual of the NAC122X? I did not find one so far
I’d imagine it’s be the same as the Flatcap connection - from a quick Google search:
Thank you, this is also what I found, but I was hoping to find the complete reference manual in pdf format, as I do not have it, for future reference.
It’s at that watermarked image site (surely Naim own the manual copyright!). I couldn’t see a separate Hicap connection graphic but they should be interchangeable. Similar connections just that the Hicap will bring more to the table.
I will get my ND5XS2 back from service and add it tomorrow, more fun in perpective :slight_smile:
