I want to connect my Uniti Atom to a Platin Stereo Hub (Hub streams to active speakers via WiSA). I don’t see any Outputs on the back of the Unity Atom, except PreAmp Output and speaker connections. The Platin Hub supports Line, Optical, Coax, Aux, and HDMI input. Am I completely daft here? Is it possible to connect the two?
Welcome and Hello,
have you tried search on here?
I’m sure your find what you are looking for,
If line/aux are analogue inputs, you can connect them with the Atom PreAmp out.
Beyond that, Atom has no other outputs. (If you disregard the headphone output, but the PreAmp should likely be preferred. Explicitly there’s no digital out.)
Thanks. It’s what I expected but nice to have confirmation.
