My stageline MM is now connected with a Hicap non DR to the 252.
Would it be better to use the powered AUX socket of the 252 so that the stageline also gets the power from the Supercap DR?
I thought that using it the powered aux from the 252 might effect the other sources negative.
And I am wondering what might be the best option.
Worth bearing in mind that the SuperCap has a dedicated DR rail that feeds just the powered aux input on the 252. So you are effectively getting the StageLine powered by a dedicated Supercap in that respect.
I agree that you can try. My money is on it sounding better without the HC in this case.
I’ve recently tried my Superline with its own PSU and powered off the pre. The latter won out but it was marginal, but off the pre to these ears was a little more fluent.
You can certainly do that. There a re numerous posts on this forum comparing the power options for the Stageline/Superline. No much consensus as to which sounds better.
