Hi all
I must be getting old…
Can someone confirm how to connect my newly acquired 62/hicap/140
I’ve got all the original guides and manuals but I’m unable to decifer it all and I don’t want it to go pop.
Apologies for the question
M
For connection details, it’s best to find something posted by james_n eg
Though you might want to confirm this is an olive hicap, plus check the connection socket details on the back in case of variance.
All connections
Obviously the sources and speakers are self explaining but it’s the power supply to 140 is mains
Hicap is mains
And pre pulls power from hicap ???
No idea on actual sockets to use or plug?
There are two cables needed, a snaic 4 and a snaic 5. The numbers indicating the number of pins in the din plugs.
The hicap gives power to the 62, and receives the preamp left and right audio - with the snaic 5. The hicap gives this left right audio to the 140 with a snaic 4.
3 boxes; 62, hicap, 140. 62 doesn’t plug into the wall and is powered by the hicap (or by the 140 without a hicap).
I actually read the manuals wrong and somehow ending up buying 2 hicaps…doh
AHH…that’s the oversight on my part so to speak
“2 different snails and the sound goes through the hicap?”
Super
Thanks for your help and time
I’m off to listen
M
