Connection instructionsconnection instructions
Hi everyone
kindly I wanted to get some help from you.
I have the cd5xs, with the stageline phono stage.
may i know how to connect both appliances on a flatcap xs.
I apologize for my awful English.
thank you all
They should connect to |“Power Our A” and “Power Out B” respectively with SNAIC 5s. Then connect “signal out” A and B to your amp. Unfortunately, the manufacturers instructions aren’t very helpful:
Power outs A and B are identical on the FCXS.
FCXS comes with a Snaic 5. Stageline comes with a Snaic 5.
Switch everything off.
Remove black plastic paddle plug from the rear of CD5XS (and put it in the empty CD5XS box).
Connect Snaic 5 from one of the power outputs on FCXS to now exposed ‘upgrade’ socket on CD5XS.
Connect Snaic 5 from the Stageline to the other power output on the FCXS. Looking at your FCXS from behind, use the 4 pin end of a Naim 4-5pin DIN interconnect from the 4 pin socket immediately to the right of the power out to take the signal to an unused 5 pin socket on your Naim preamp or integrated amp.
Check you have done all this.
Switch everything on including your CD5XS.
Open a cold beer (optional).
