Hello to the community, I apologize in advance for my not perfect English … I have problems connecting with HDMI ARC output of my UNITI ATOM on Samsung FRAME TV. I cross-checked and it seems I can no longer use the remote control of the TV to directly control the amp. It worked 9months out of 12. Thanks if you can help me
Has anything changed in firmware on the Samsung? Try a hard switch off (plugs out) and then unplug and re-connect the HDMI cable, and then power back up the TV and Atom.
Samsung have a nasty habit of providing firmware updates that remove functionality. I’ll try my muso 2 on my Samsung Frame 43" later and see if it works.
I can report the my older 55" samsung lcd works fine with the muso 2 via hdmi arc.
Love the samsung picture quality, but will not buy another due to them making changes and not communicating the negative consequences of any updates.
