Connections for Stageline with HiCap and NAXO 2-4
I hope someone can help with this please.
I have just acquired a Stageline, as a long overdue replacement for the internal phono amplification of my Linn preamp. I run SBL speakers with the active NAXO 2-4 and have loved that combination.
At the moment, the NAXO is powered by a HiCap and works well.
Adding in the Stageline I want to check precisely which connections and signal path I should use- I wasn’t able to find the exact combination in the forum of my hybrid Naim / Linn system. If I’ve understood correctly, the stageline is powered through a SNAIC out of one of the 5 pin outputs on the Hicap.
Some questions:
  • does it matter which output powers the Stageline and which the NAXO?
  • I assume the signal path of the existing NAXO to amp doesn’t change, and that the Stageline’s output flows through the HiCap with a connection into an input on the preamp? Is this correct, and which connectors do I need to use on the HiCap?
Sorry for the basic questions, I just want to be absolutely sure I’m not creating any sort of loop within the HiCap or anywhere else!
thanks in advance
best wishes
Andrew
Andrew, a HICAP can only power a single item, so you can’t use one HICAP to power both a NAXO and a Stageline. You will need a suitable power supply for the Stageline; the most basic is the i-Supply (s), next a Flatcap, then a HICAP, or ultimately a SUPERCAP.
Note that you will need a SNAIC5 and a 4-5 interconnect if using a Flatcap, HICAP or SUPERCAP.
Welcome to the forum.
The answer is as described above but I would recommend a Naim Flatcap XS as it is likely to be the best compromise between cost and performance for the Stageline. If you have a suitable Naim Pre-amp there is likely to be be a 5-pin combined input and power socket which can power tethe Stageline (usually labeled as AUX2) and if not already being used it will probably have a plastic cap cover over it.
Thanks @Richard.Dane and @Robinho - really appreciate your clear replies.
I clearly didn’t do a good job with my homework - I’d seen it stated (not on this forum, admittedly) that a Hicap would power both.
I’m heading off to source a Flatcap now. Bad news for the bank, good news for the rack which will gain another resident….
Thanks very much, Andrew
Just one further thought to mention is that the blackbox Flatcaps will power 2 pieces of Naim equipment. For example I have a Flatcap XS powering a CD5 and Stageline.
Thanks! Thereby opening up the danger of future upgrades…. :wink:
