Hi
Do I need a legacy app or will the current update to date app on Google control tidal lossless
My dealership is unsure but is willing to sell me a ndx 2 though
Hi
The NDX will play the built-in Tidal but not Tidal Connect. The current app will control it. There is no ‘legacy’ App for streamers.
That’s what I needed thanks
M
I think you need to use the Naim app to play Tidal with the NDX (latest firmware) whereas with the NDX2 you can use the Tidal app because it supports Tidal connect.
The Mk1 NDX will need the latest firmware (version 4.9) for Tidal, so if it doesn’t play it through the Naim app, check it is up to date. Also, some of these incidents occurred very early NDX were unable to support this without a hardware upgrade.
All this is assuming you really do mean an NDX, as opposed to an NDX2 which I recall you were thinking of buying a while back. The NDX2 has none of these problems and can play Tidal via the Naim app, Tidal Connect, Airplay, Chromecast, Bluetooth or Roon.
Hi
Yes I was and still considering the ndx2 it’s just the vast price difference makes the original a little appealing.
But I don’t like problem or workarounds so I’m going to dem the 2 and an original so I’ve got a few hundred miles in the next week lol
The Mk1 is cheap for a reason! If you understand its limitations and can live with them, it’s a possibility, but if service and parts availability prevent a repair it may seem like false economy. If this is a long term purchase, I would go for an NDX2, or even an ND5XS2 at a lower price.
Yes the nd5xs with a white light would fit my CB setup nicely
But they have discontinued it
Presumably you mean ND5XS2? Yes, it’s discontinued, as is the NDX2, although it’s not impossible that a dealer may have some old or ex-demo stock available.
