With the installation of IOS14 and since I did a clear history and website data. I am constantly having this screen displayed every time I open up safari. Similar problem to a few months ago. Not sure if the web developer has been fiddling again Itâs ok if I havenât closed the browser fully down.
Itâs not the web people fiddling, I updated to iOS14 last evening, I had the cookie screen just the one first time after the reset, since then it hasnât shown, just like it was before. I suspect it might be somethingâs changed at your end.
It does it on both my iPhone and my iPad the only thing that has changed is IOS14 iPadOS14. It doesnât happen on my iMac or Mac Mini they havenât had an operating system upgrade but a new version of safari was released the other day.
Do you fully close safari by flicking it away so that it doesnât run in the background?
This problem has occurred in the past when using safari to view the forum and in the past it has been down to a change the web developer has made. Though that may not be the case this time.
What app do you use in iOS to read/post to the forum? Iâve been doing it from the Safari webbrowser. I installed Discourse Hub but couldnt find the forum.
