Copy HDX Music to a USB Storage Device
I am trying to backup my HDX (1.7c) music files to a Sandisk 1tb storage device. My PC (Windows 11) displays the HDX in Explorer Network but when I open it it takes me to a page (http://192.168.x.x:49152/nsdevicepres.html that says:-
This is the default web page for the Naim UPnP Media Server hosted by this device. You can manage this media server through any standard UPnP Control Point.
I was hoping that it would show music files in Explorer. SMB 1.0 is enabled. I can open music files using recently downloaded Flashplayer-32-sa but it has no copy facility.
I am not sure you can do that I could be wrong. You need to create an smb share somewhere else on your network and set it up in the hdx as a store
If you want a proper backup you’ll need a NAS. Then you can set up the HDX automatic backup and it will update daily after the initial backup. If you just want a copy of your existing files you should be able to find the MQ folder and copy it to a drive if your choice.
Just want to copy my music to usb storage device. I’ve tried your solution by:
Windows: Open File Explorer and click on Network in the sidebar. Look for the Naim HDX (e.g., NSHDXxxxx) and double-click to access it.
Navigate to the Music files: Browse to the Music sharepoint and open the MQ (Master Quality) folder. Inside, you will find your organized artist and album folders.
Copy the files: Select the desired albums or tracks, right-click, and select Copy
But as I said previously, I see the HDX in Explorer Network but when I open it it goes to
No HDX Folders are shown. Also when I try to access system settings on Desktop Client it says
Room ID must be between 1 and 255. I operate as a stand alone and have never set up multi room.
Maybe this can help.
No. I’ve read all these but, as I have already said, the Naim HDX symbol shown in Windows Explorer Network does not take me to any HDX folders. Just to the webpage described previuosly.
I see, maybe you can try connect it to a Mac and see if that works?
That seems to be a Windows issue, does it behave like that with other network drives or just the HDX? As a Mac user I’m not sure why you’re seeing a URL/IP address when you’re looking for folders: maybe a PC user will be able to help.
Fixed it.
Opened Explorer Network. Then selected RCH-PC. Then typed in at the top of Explorer address bar 192.168.1.xx and all the folders appeared.
NB had to enable SMB 1.0 Client first.
