Hi all,
As per the title, i need to know the s/pdif coax digital output voltage and the main site is down for me to check - my booklet thingy tells me to refer to the site so just wondering if anyone knows the answer?
Many thanks
Hi all,
Many thanks
To be compliant SPDIF the (analogue) output voltage needs to be 0.5 to 0.6 volts peak to peak into a 75 ohm load.
The spdif on the core is very good
I only stopped using it as my dealer insisted that I would get better sound if I changed to local ethernet…which I did
I didn’t get the promised improvement
The two things are quite separate and not really related…
Thank you - do we know exactly what it is, i.e. 0.5 or 0.6? running it into my dac which has an input of 0.5.
The specification allows it to vary… so it doesn’t matter.
