Can someone give me a hand on how to check the remaining available disk capacity on a Core system?
I checked in the Naim Apps and wasn’t able to find any reference to disk capacity.
Thanks for your support.
It’s in the Manage Music menu option under the gearwheel icon. You select Configure Music Store and get the screen below then select View Store.
Best
You beat me to it.
Many thanks David for your swift answer, you are right I can see the total disk capacity but not what is used or free. Any other idea on how to proceed?
Yes I got it under another tab so many many thanks you are a boss.
It should be where I said. Here is the screen shot of View Store from my Core. The space is shown as “Available” (I think you may have misread the instructions in my first post!).
Best
