Hi all are these still worth a punt
Yes, if you have a pole, and the Cam or Isis.
IBL / SBL might be better with your kit?
I had Credo and SBL, each with 180 then 250. The Credo was a 6/10 from me, SBL 8/10, and gets better and better if you upgrade the other components. Needs more careful setup though.
Bruce
I had Epos ES12s, and after them, Naim Credos. I was catastrophically lacking bass. While this was understandable with the Epos, it wasn’t so with the Credos. I needed much better amplification, and not passively, but actively. I didn’t have that option back then. However, these days, there are better options, in my opinion, no matter how you look at it.
