Can anyone recommend an FM / DAB indoor aerial for a Unitiqute please.
I appreciate there will be a compromise in finding an aerial for
The multiplexes I can receive are from transmitters or repeaters in two different directions so a not-so-directional aerial is needed.
I’ve been using the supplied simple wire dipole. It’s adequate with some DAB artefacts but I keep having to retape it.
You want one of below. I use one on my UQ in central London and it does a brilliant job. Get one without the USB powered amplifier. Mine has a magnetic base and is about the length of my hand, for scale. I tried loads and this is the only style that did the job on both FM and DAB. This was sourced on a popular auction site. When I just checked I couldn’t spot the exact same version, but there are some that look similar listed under indoor TV aerials and I remember some of these also supported FM and DAB.
