Hi,
During a DAB station scan, it indicates around 100 found. At the end of the scan, the screen shows ‘NO STATIONS’.
What should I do?
Many thanks…
Hi,
What should I do?
Many thanks…
You could try a factory reset. You do that via the spanner/wrench button on the remote.
Otherwise it’s probably back to Salisbury. DAB sounds terrible incidentally, so if you are just doing it mainly out of curiosity, you might want to just forget it.
