My windows 10 Dell laptop is like a couple of years old.
It is hooked by usb to dac v1.
Should I be downloading/using any special naim driver to be able to stream 24 bit 192 khz?
Appreciate the clarification.
Yes, see here https://www.naimaudio.com/news/21751/dsd-playback-now-available-naim-audio-dacs
DAC-V1’s asynchronous USB input allows the connection of a PC or Mac directly. Mac users need no extra drivers, Windows, including Windows 10, users will need the new version 2.00.0 driver downloadable here.
YOu can also look at Audirvana software, to see if it has features you like.
sorry - i forgot to mention that i am using jriver 26 which is the latest version i believe.
do i still need to download the 2.00.0 driver?
Hi yes you need the windows driver. Also see this set up guide for jriver
