Hi, I’m not sure if the USB input of the V1 would support that. Also, I don’t think Chromecast is the best way to use Roon for sound quality. Maybe worth using a direct connection from your Roon Core to the V1, maybe SPDIF depending on what connections are available on your hardware.
Hi. Having used a MM into Dac V1, via a decent usb lead, for a long time, then home demo’d (& purchased) ND5xs BT - the xs completely trounced the MM/V1 - about to add a ‘preloved’ XPS (2): can’t wait
Don’t waste you’re money, even on a second hand XPS, I have compared both the DAC v1 against the NDX and the difference is zilch, what pre amp are you using?
The ‘preloved’ (2003) xps ‘killed’ the sound on the nd5xs, it went straight back & I got a wonderful deal with the dac v1 & nd5xs; I’m now the proud owner of an NDXbt.
Using with: 202 (napsc fatcap xs - which, when funds allow, will be traded up for hicap) 200 into ATC sc11’s.
Going back to the original question: having used the Dac V1, as good as it is; a quality streamer is FAR better
