Did anyone try Alto Extremo Exact feet for CD player? If I use one set of three, I should put two forth one back or opposite? Thanks!
Not tried them
But I would hold the CD in my hands and see if it felt front heavy or rear heavy
Then put the two feet at the heaviest end
The Alto extremo seems a quality item of a common sort, most usually recommended to have one near the transformer, one near the output devices and the other to give a balance.
With Naim… With the cd drawer that swings out on most of them, I found putting one near the underside hinge bolt at the front and two at the back - since that drawer has most of the working and vibrating mechanisms channelled to that point.
