Apologies for an embarrassing question, but I’ve just disconnected my Atom from the switch and am not sure which way round the Chord Signature Super Aray digital cable should be connected. Arrows from Atom to switch or switch to Atom. Struggling to get my head around which is the source.
Assuming you are streaming something either local or from the Internet, then your network is the source and your Atom the destination. I can’t believe it makes a blind bit of difference though…
Best
Thanks.
That’s what I thought. Just feels counterintuitive. And I agree it almost certainly makes no difference.
Just yesterday I decided to switch my Chord streaming cable to point at the switch as source and it made naff-all difference too!
