Hi
I used to have a Unitilite and used the din connection pre out to my Cyrus amps
Now I have a star one analog connection is for av but I need to connect my turntable but the other input is a din one will my old lead have the same wiring configuration as the input on my star?
If not I will have to purchase a new one
I know I will have to purchase female phono adapters
Steve.
If you were using the pre out on a UnitiLite it’s a 4 pin 240° socket. The Din input on a Star is a 5 pin 180° socket. That hopefully enables you to work out what to do.
I’ll look into getting a new one
