I can’t seem to be able to disable the Tidal input on my 333, if I untick the checkbox it immediately turns back on again! All the other inputs are fine, just the Tidal one.
Does anyone else see this? Any thoughts? Am I missing something?!
I seem to be able to disable Tidal on my 222. It logs you out, so to re-enable you need to login again (all in the Naim app).
Were you streaming from Tidal at the time?
Hi, no, I use Qobuz so was just turning off inputs I don’t need to tidy up the app. Everything else turned off fine … very strange
Same exact issue here with Tidal, and I’ve never even logged into it.
Same here, neither Tidal nor Spotify inputs can be disabled. It seems to depend on the streamer though, as I can disable them on my Atom and QB2.
Ah thanks @jusphish and @ChrisSU … not just me then
If anyone that’s on the beta is reading this maybe they could report it as a bug please?!
Ah yes… I just tried to remove Spotify and that has the same problem on mine as well. No problem removing either on the NDX 2 but NSS 333 doesn’t want to let them go!
Naim is looking at it.
That’s good news as my 333 won’t allow me to disable. Hopefully Naim fix it soon.
Yep, hardly the end of the world … but a bug is a bug
