This will be because someone who has connected to your Qb in your house is now using Spotify elsewhere and is casting to your Qb. Itâs the way Spotify works. The answer is to ask them to stop. You can set Bluetooth to secure via the Bluetooth input on the app.
Adding to what HH said, if you canât contact whoever it is or you donât think that is correct because you donât think anyone ever connected to your muso, you can remove the association with someone elseâs Spotify account by doing a factory reset of your muso. That will resolve the problem, but you will need to reconnect it to your WiFi if that is how you connect it to your home network.
The assumption is that if someone has connected to it in the past and itâs in their list of available players, then sometimes it will get selected by mistake or defaulted to or something like that. Itâs not a Naim thing, but rather a Spotify thing. Itâs just how they do it. There isnât anything Naim can do to stop it happening.
Yes i understand the reasoning behind it and agree, but to allow it to connect to a speaker when itâs no longer on the same network is a bloody stupid idea, as the app also defaults to the speaker it was connected to last, regardless of where the device is in the world.
Yes indeed, and iâm not really blaming Naim as such, but why Spotify would allow connection to a âremoteâ speaker when you are nowhere near it to listen to it!
It could easily be stored in the app itself, and not be made available until the device has reconnected to the relevant network.
How is Spotify supposed to know âthe relevant networkâ? You could easily have moved your WiFi speaker (Naim or otherwise) on to a different network, for example if you are travelling for work or you took it to a mateâs for an evening or are on holidayâŚ
I decided to change the room names on both units, and now, occasionally, ill open the App and they will both revert back to what they were called before!
I thought it might have been me, but it appears to be the Naim app.
You canât conclude that itâs the Naim app because half the software involved is in the muso, so it could be the muso firmware. anyway you should report it to Naim support because thatâs the only way it will get fixed.
The Spotify app contains an option to âonly see local devicesâ, but this is disabled by default. If you enable it on your device then you only see devices on the local network that youâre connected to. I donât know why itâs disabled by default, and I donât understand why they allow you to even connect to remote devices. Seems like an exploitable flaw to me.
As JSaville mentioned, enabling âShow local devices onlyâ should resolve this issue. This can be found in Spotify settings > devices.
From the Naim APP I also recommend you go into settings > Input Settings > Spotify, from here you should be able to logout the user who is logged in to your Mu-So.
Once you have logged out the person who is using Spotify on your Mu-So, the only way they can log back in is to be on your LAN again.
