Not sure if this is the correct forum to post this, apologies if not.
I’m using iOS Safari to view and post in the forum. At the top is a banner for “Discourse Hub” saying available on the iOS store. Does anyone use this app and are there any advantages to non browser forum access?
The Discourse App makes the forum much more useable on a small handheld device. It’s well worth using it if you browse or contribute to the forum on an iPhone in particular.
I find going to (http). community.naimaudio(.)com on my browser (Chrome) easier than Discourse.
I use this on both iPad & Windows.
But others will have other opinions so why not try both & decide yourself.
Interesting - I have had some right nightmares trying to post from my iPhone on safari with a near-invisible entry window! Might give that a try - though my experience with another app on other forums (forgotten the name of it) makes me hesitate a bit
I use DiscourseHub for the Naim amd Roon forums. I don’t find any significant difference between that and Safari, but it keeps the forum page separate from the multiple pages I often to keep open.
