Display ndx2
@Protegimus I confirm that at least in my case, the display remains off only on streaming while if I connect the USB stick, the screen turns on and then turns off with each track change. Can you check if it’s the same with you? @sktn77a
I have my regular play library on a Samsung 512GB flash drive plugged into the front USB socket. I have the display turned to “On” permanently while playing music, so can’t answer your question.
@sktn77a Listening to music through the USB stick, the defect does not appear. It only happens if you listen in streaming
