Do You Like Bass - Deep Bass & Texture?
Tonight I thought this thread was going to cost me a lot of money…
Opening of this track has isolated bass only. A horrible vibration came from the right speaker. I played again with head near cabinet, it sounded like internal down firing woofer :worried: Panic, SWMBO loves her speakers.
Tried holding speaker terminals in turn, no change. Then had the inspiration to check feet. One of the feet bolts was only very slightly loose, thankfully tightening removed all vibration.
Lesson learned - I already check cables, speaker terminals and jumpers on both speakers weekly, as our cats have a tendency to go behind speakers. From now on I will check feet bolts too! Obviously lots of bass had shaken loose.
Back to listening….low, low bass on this one
Nuuk, the first track from Thomas Köner’s album Aubrite. Play loud for maximum effect.
I’ve heard the James Blake track quite a few times on lesser systems - just read your piece and tried streaming it via Tidal into my Harbeth HL5’s through a Vincent SV236mk amp.
I see what you mean. Subsonic wobble between the speakers I’ve never heard the like of before!!! Quite startling.
A good one for vocals only (albeit through a vocoder) is ‘A Satisfied Mind’ live by Bon Iver. The vocals wobble…
Somehow this thread has evaded me, will give it the attention it deserves over next few days.
Cheers @ratrat
Just listened to Nuuk (air) - first track of his fifth album “Nuuk” ( 2005 ).
Is that the track you mean. It’s a good one :+1:
R
Hey Iain
Implosion. That’s monstrous.
Had to know - how - what - who ?…
This is what the internet said…
The sub-bass in the first track (“Hooked” by The Bug) on The Bug vs Ghost Dubs - Implosion is created through a combination of extreme industrial sound design, high-pressure, low-frequency oscillation, and deliberate, “in-the-red” production techniques designed to emulate sound system vibrations.
Key elements creating the sub-bass in “Hooked”:
  • “In-the-red” Beat Production: Kevin Martin (The Bug) uses heavy distortion and maximized gain, pushing the mix to its physical limits to create a claustrophobic, “booming” sonic atmosphere.
  • Industrial/Industrial-Dub Fusion: The bass is characterized by “sinister, slo-mo slogs” that blend industrial drone with classic dub weight, creating a “pneumatic” or “charred-to-the-bone” effect.
  • Sound System Emulation: The bass is mixed to emulate the physical experience of high-power sound systems, such as Jah Shaka’s, focusing on immense sub-harmonic resonance that is described as “bone-rattling”.
  • Mastering: The tracks were mastered by Stefan Betke (POLE), who is known for his work in dub-techno, ensuring the bass remains incredibly deep while staying "heavy without continuous distortion”.
The first track, along with others on the album, aims to make the sub-bass a “physical mass,” often described as “10,000 fathoms-deep,” designed to be felt at extreme volumes.
To be honest, had to turn the volume down.
Really enjoyed “Engine Trouble”, in fact the whole album “Bass Chalice”, (2005). Very much my cup of tea. Loving the electric bass. Thanks.
BW
R
I am shaking with hyperbole…
Two great recommendations - Francis Thirteen - Nenad Vasilic - really enjoyed both.
Particularly enjoyed listening to Bass Room ( 2019). and have come back to this album several time since your post. What an amazing musician. Probably one of the most interesting double bass pieces I’ve heard. Brilliant. Thanks
BW
R
I picked up a few albums from a subwoofer forum, Implosion was one of them.
Our system unfortunately isn’t good enough to do these albums justice. The baby SF floorstanders are fabulous speakers which we enjoy immensely, but they simply can’t move the bass weight required. I must try some of these in the office, our sand loaded MA sealed boxes sometimes surprise with bass weight and speed.
I shall continue working on SWMBO on the new speaker front, but she is mightily attached to her beautiful SFs. I’d have ATC 50s in a heartbeat.
Thanks for the research. Typed POLE into Tidal and Stefan came up and there are a number of avenues of exploration there. Once I’ve got my head round it I will use some chatGPT assistance to delve further. Exciting to discover new music! :heart:
I meant the first track, simply called “Nuuk”, on the album Aubrite | Thomas Köner | Force Inc. / Mille Plateaux (also available on many streaming services). Indeed Thomas Köner has several tracks with ‘Nuuk’ in the title; maybe some of them have similar impact. [I didn’t try them all…]
If it’s of any interest or help, I have compiled a public playlist on Tidal that contains many of these recommendations in this thread. It has the same title as that suggested by the OP, namely “Do you like bass - deep bass and texture?”
Can it be exported to Qobuz or Spotify?
I’m not a Qobuz user, but I do have a Spotify account. I’ll look into the method for importing playlists from Tidal for Spotify. I think that there are a couple of apps that could be used for free for a limited number of tracks. Watch this space..
Shostakovich 11th Symphony, second movement. The octave doubling by the strings, the contrabassoon, the tam-tams … all this is pretty freaking deep but it’s the layering that makes it feel like a bottomless well.
And when it stops, it feels like the pressure that had kept you upright has vanished, and you fall straight in.
The “Do you like bass - deep and textured bass?” playlist has been exported to Spotify. Also available on Tidal.
hmm… I can not find it on Spotify unfortunately
I can’t find on Tidal. Is it set to “public”?
I’ve checked - both the Tidal and Spotify versions of the playlist are set to public. You may have to search for playlists by Malcolm Pollard.
Or
Spotify:
Tidal:
See if that works.
Thanks. Yes, I’ve now found it on Tidal.
