Hello everyone,
Have just got an N 272 which is connected to my router via ethernet cable.
Can I use the Naim app with my windows 11 laptop,or do I need an i pad?
I dont use a smart phone.
Thanks.
There’s no Windows App available. Only for Apple devices and Android
You can use the remote control for pretty much everything if you prefer, as long as the 272 screen is visible. Otherwise you need an iPhone, iPad or Android device. Newer Macs can run some iPhone apps too, or you may be able to use an Android emulator on Windows although this is not officially supported by Naim.
A work around could be to get a cheap tablette on which you could run the Naim app.
If you are into streaming it would definitely help your DJ experience. ![]()
Thanks everyone.
Will any Android device run the Naim app?
I see they go from about £100.
You would not really want an old version of Android in your home, these would not receive any security updates. Try to get at least Android 14. And these indeed start at very competitive prices, a brand new Samsung A9 tablet for example.
Thankyou,
have taken note.
