Thought I’d start a thread on this, rather than possibly derail other threads that are asking for more specific advice.
Whilst I think there’s a place for detailed room calculations and correction, I really don’t think I’ll ever go through the hassle, even if I bought equipment that supported it.
I also can’t be bothered with room treatment. And don’t want the intrusion of it into the house and listening environment.
I know that means I might be missing out, but it isn’t a set of compromises I want to make.
What I would consider is a device/function that does its best with my current sources. And ideally, but not necessarily, used my current speakers and in their current position. I don’t know how widely the same views might be held though!
I’d consider the following options
- A preamp based system that played a test sweep with no specialist equipment and applied gross room correction for major bass/room nodes, possibly also correcting general trends in brightness.
- An active speaker based system that did the same.
Both would work with all sources, which I think is important to most people?
On the speaker side, I think the Buchardt Anniversary 10 do a neat thing, offering room correction via their internal DSP. IIUC it does require a calibrated mic though. After reading the manuals for the Hypex active speaker modules, I can see the potential for modules like that to apply driver unit crossover and room correction functions.
Both approaches above appeal because they would enable all sources to be corrected. Unlike Roon, which wouldn’t help my turntable, or a streamer source with DSP, which also wouldn’t help my TT!
The problem with lots of this is the need for a calibrated mic. I wonder if a nearfield measurement could be made with a mobile phone, and calibrated sufficiently (it would have to be some sort of relative calibration) to negate the need for a measurement mic. Then use the phone at the listening position to record the same test sweep and fit a bunch of corrections to the resultant response to dial down room modes and/or deal with brightness issues. Ideally an app would walk me through the process, and not require a trained specialist to assist.
Anyway, mad ideas aside, anyone else really not into the palaver of room treatment, or asking a specialist dealer to calibrate their system, but would be up for a simpler solution if one existed?
I suspect a manufacturer who developed something useable might well do ok out of it?
And lastly, does something like this already exist?
