Does a Superline bought in the UK work with a US Naim preamp/PSU/Integrated, or is there a voltage difference that needs conversion? I feel dumb for asking, but I honestly cannot find any info.
As you seem to know, Superline needs either an external PSU or a power feed from a Naim preamp; in either case, it does not plug directly into the wall, so voltage is a non-issue for US vs. UK. Any unit will work in either country.
Thank you @AHT! I assumed as much, but it is for a friend and I wanted to be certain. Naim components often times confuse me on what they may or may not do electrically no matter how much logic I might own in the matter. Thank you!
All Part of the Magick…
But… definitely better to ask, if unsure.
