EAC ripping problems
I’ve always ripped my CDs with Exact Audio CD, it has always worked flawlessly. However I’ve been facing problems with an album I bought, Pat Metheny - Dream Box: the disc seems to spin at lower rpm with sonorous clacks. The process always takes ages and the result is uncertain. Some tracks have been ripped correctly, others not. When I tried the process again I managed to finally rip some but still not all of them.
So I wonder, what would you do to solve this kind of issue? I wonder if it’s the album to be faulty and need to ask the shop for a change. I tried it with other players and the problem seems to happen again. Fun fact: I managed to rips some tracks by tilting the laptop (rpms increased and clacks mostly disappeared).
I’m curious to hear your point of view. Thank you very much in advance!
I use a Mac mini with external drive and xld ripping software, whenever I have slow rpm with lots of disc access leading to difficulty getting correct rips, it is always the cd.
I suspected that, thanks for sharing your experience. Can you actually play those CDs on CD players? Did you ask the shop to change them?
If the cd was not new a clean of the cd would sometimes get it to rip.
If it was new, I always returned it.
If it had a problem ripping it wouldn’t play as a cd.
Have you tried ripping with iTunes ? if EAC would not rip the CD, try iTunes, never had a failure ever using that route, admitted its normal CD quality.
I also use EAC to rip my CDs. To back up what others have said whenever I get the slow RPM or read errors it has always been the CD. Usually cleaning the CD clears the issue but once I had a copy of Kate Bush’s Aerial that could not be read and had to be returned.
When there is a problem reading the CD EAC shows the retries on a red panel which lights up to show the progress of the retries with the variable settings tried by EAC.
@kend the CD is brand new, perfectly clean and has no scratches. I think today I finally managed to fully rip it with EAC after the 7-8th time, still I’ll ask for a change even though I only stream locally. Unluckily I can’t check if it would play on a normal CD player, I’d be curious at this point.
@Cmax nope, thanks for your suggestion. I’ll consider it if my latest rip is faulty. I’ll check later! I almost never had such problems, maybe once but on a very small scale. This CD instead has been a complete disaster, really. I also wonder if it might have anything to do with the copyright protection.
@LutherP during my very latest rip I’ve turned upside down the external disc reader I have and I’ve also activated the secure ripping mode on EAC. No errors appeared this time, I wonder if it was only luck for once. I’m curious to listen to the whole album to see if it worked as intended. Fingers crossed!
I used EAC to rip my CD collection to hard disk. The clicking you describe sounds like a disc I had where the hole was not punched through cleanly and there was a small fraze on one side of the hole causing it to wobble when spun up. If it was a new disc I would return it. If it’s an old one then trying cleaning off the fraze with a nail file or similar. I also had a warped disc that would not rip, again it wobbled when spun up and you could hear it ticking / rubbing against the interior of the drive. That one went in the bin. Just to add I never encountered a problem with copy protection using EAC
Yesterday I finally checked the ripped files; luckily no errors at last! However I’ll ask to change the CD, it’s clearly faulty considering what happened.
I have an iMac I use an Apple Super Drive and rip with XLD to AIFF. I can’t remember the last time I had any problems.
I’m waiting for the replacement, hope everything will be alright when I get it. Needless to say I’m curious. Thanks everybody for your help!
I rip with dBpoweramp but use iTunes when that fails, I have only had one disc (in about 1000) that I never successfully ripped and that also happened to be a Pat Metheny album. I suspect the issue was some sort of copy protection, as even when it seemed to have been successful what I heard was a horrible scratchy sound rather than music.
Roger
I checked the final rip and thankfully it sounds fine (meanwhile I asked a replacement for the CD). I suspect it might have been the copy protection but I’m not entirely sure as the disc seemed unbalanced when spinning. No idea!
Re Copy Protected …… dBpoweramp has a feature that I’ve used, it doesn’t always work or so dBp say, but has for me.
Open CD Ripper.
Click on “CD Ripper Options”
In ripping methods, select “Defective by Design”
Rip the CD.
Thanks, Mike, but I did try that, and a host of other possibilities I found online. It was a fussy disc, which played OK on my CD5XS but not on the built-in drive on my computer. In the end I got a streamer that supported Qobuz and it was simpler to just stream the album.
Roger
There was a problem with discs on the Richard Thompson boxset and to a lesser dregree with the Bobbie Gentry boxset.
The discs are not exactly flat. You’ll probably find they play OK but ripping them results in errors more often on the last tracks.
Could be the same issue with the Pat Metheny CD.
Thanks @AndyP, that might also be the issue. I’m not sure whether it’s the protection or the disc itself. I’m curious to see how things will go with the replacement.
I have ripped this actual CD with Freac, and had no problems.
I think you have a faulty copy.
Indeed @Nigel1957, that could possibly be.
