I’ve just returned from a trip away and on powering the hifi up, I have no sound from the right channel.
NDX2, NAC 282 with SuperCap driving NAP 250.
All leads checked and power recycled a few times. When I select MONO, I get the right channel speaker back, so proving the NAP 250 and the SuperCap, I think.
You take your boxed item to your dealer. Tell them what the problem is. They send it to Naim. Naim fix it. They send it back to dealer. You collect it and pay.
It’s shame because I used to enjoy taking the odd thing in, meeting Sheila, having a mini tour, saying a few hellos, then going back a couple of weeks later for collection. I loved the personal connection, and meeting Sheila and other staff who were, to my mind, unofficial brand ambassadors.
But this is old fashioned. The world has moved on. But your NDX2 will still be fixed.
I had just used the USB output on the Innuos Zen Mk3 to feed an iFi Zen Dac v2 set in fixed output mode to feed the Aux 2 RCAs on the 282 and thought I’d give the NDX2 a last chance before removing it from the stack… and it’s now working.
I’ve power-cycled it a few times and the fault hasn’t reoccurred (yet).
There is a fault, even if it is intermittent/transient.
Is it worth sending it in? I hate my kit going off into the world of the couriers!
Of note, what a cracking little DAC the iFi Zen DAC is! I use it a lot as a headphone amp and have always been impressed by how it sounds. But plugged in the 282 it sounds brilliant. I’m quite amazed!
I suspect the fault will return soon enough, I’ve been there, most likely the relay. Naim should sort this FOC as there’s a ridiculous amount of failures.
You should let Naim, or your dealer know straight away if you have the full 5 year warranty, otherwise it might be fine until the day after it expires. Then you have the option of keeping it for now if you don’t want the hassle of a return.
For a bit of further diagnosis, I find it useful to have a selection of din and phono cables, even if they are just super cheap things for testing. You could then try a different input on the 282, just in case that’s where the fault is, as well as trying the RCA out on the NDX2.
I did the very same thing many years ago. I rang Naim in advance, and was told that the unit could be fixed in a few hours. Sheila was an absolute treasure, and a fabulous (if unofficial) brand ambassador for Naim. I dropped the unit off, went out for a (dry) spot of lunch in a tiny pub in Salisbury, and returned a few hours later to pick up the repaired unit.
