At the risk of asking a dumb question in such a technical forum, I have just bought an EE8 which I have connected (via my Amplifi mesh unit) to my Nova. Thus far, I am only seeing the Amber (100 mbps) light for the Nova - whereas if I connect my Sky Q box into another port on the EE8 it glows a satisfying Green (1,000 mbps).
The input is similarly Green, so the mesh unit (in turn connected to my Virgin broadband router) is working fine and feeding through the 350+ mbps stream coming into the house.
So, why should the offtake to the Nova be indicated as 100 mbps or less. Is this what it should be doing or am I missing out?
Thanks for any advice!
