Just got back into the ‘game’ - the hifi game that is after a very long hiatus. The system in my new home has never sounded better - but decided to tweak around a bit.
Long story short - this is how I have it - with excellent results!!!
Comcast Cable into Arria Router, hooked to an Amazon Eero Pro 7 Endpoint (that acts as a router). This goes into a basic BrosTrend Switch, and the UnitiCore, and a Roon Nut device is also plugged into the switch. (Amazon.com). Cables are all BlueJeans 6a, with some ferrite thrown on for good measure. Ifi 12V amps throughout (except for the switch - which takes usb-c which I don’t have - and probably a different voltage too), and the Roon Nuc also takes its own standard plug. Powerstrip is the Tripplite isobar ultra, a consumer grade sub $100 unit that has surge protection, RF filtration etc.
Here’s where it gets interesting.
For complete isolation, Got a mesh (Eero Pro7) Endpoint in the living room, on the otherside of the room as the WiFi. This is plugged into a TrippLite Isobar Ultra AV (10 socket) power strip with RF filtration, surge protection etc etc..
Got a 16ft Cat6a cable going to the Hifi, from the mesh switch, but into a EE. Ferrites on it again. From the English Electric to the ND555, got a Chord Epic Streaming Cable, again with a ferrite on it.
Noise floor way down, even compared to what I had earlier.
Reason I tried this as an experiment -
Earlier, I had the ethernet traveling from the switch through the wall into the living room - and I’m pretty sure it was picking up all sorts of gunk and noise - which would then be taken care of by the audio quest cinnamon cable to good effect - but I definitely needed that cable - and the bluejeans with ferrite wasn’t enough. Using the mesh system that I have at home anyway means I can bypass the cable picking up stuff as it snakes its way through the house.
Next question is - do I need the EE switch in the middle - or can I just hook up the bluejeans into my ND555 directly. it’s a 15ft run - so can’t do an expensive cable..
In any case - the fundamental logic here is the following - it’s not about bits and bytes - all that is take care of anyway. its all the other random noise traveling on the wire that gets its way into the ND555 despite everything else and needs to be minimized.
I had done a similar experiment 7+ years ago with a Nest mesh system - and it definitely had made things worse back then - the Nest itself injected bad stuff - and I didn’t have fancy switches in the middle…
