I have just brought a recent 2016 Superuniti BT and trying to set it up.
I want to connect to my WiFi network but my password uses a ‘_’ underscore symbol in it and for my life cannot seem to be able to find that anywhere on the handset keys (hidden behind a key somewhere I hope).
I could re do the WiFi password but then I’ll have to rejig all my other devices with a new password )
I don’t have my Superuniti with me but as far as I can see, there isn’t an underscore button
Hopefully you’ve now got yourself up and running.
Bear in mind, if at all possible, a wired connection is preferable. The wi-fi on these machines can be a bit flaky, with drop-outs unless the wifi router is really quite close to the Superuniti.
