A strange thing happened yesterday.
All playlists were empty when viewed on n-Serve, iPad app or iPhone app. A ‘no tracks in the playlist’ message appears.
These playlists were all created using n-Serve. (I typically use playlists to deal with the problem of Naim failing to recognise compilation albums). The list of playlists is visible.
All the music that should be in the playlists is visible and can be played. Rebooting the US, n-Serve or the apps has no effect.
Before I reconstruct the playlists has anyone any other ideas?
