« Between the wall socket and the switch I use BJC to avoid introducing noise and crap which travels through the tens of meters of in-wall cabling. I have Netgear GS108E switch, which has measurably one of the lowest noise floors around »
If I knew that before, I would never wasted my money on the Audioquest diamonds and PhoenixNet.
I owned the English Electric 8Switch (with LPSU) before Netgear GS108E. I noticed the Alpha Audio review/measurements of several switches and got curious so I bought one GS108E (costs around 30-40 euros). I preferred its sound to the 8Switch, better flow of music and PRaT. 8Switch maybe had a slightly higher resolution but it sounded more clinical/hifi than GS108E. That might fit some setups but not mine. So I ended up saving around 400 euros and got better sound quality, I’m happy.
The first switch I had was the Netgear Gs105. Added a high quality psu, then I was happy.
However found the Cisco 2960 having better prat and more grip.
The Etheregen next, specifically with a good lps, was another world for me.
PhoenixNet finally bettered it, but the gap was not that big as previously.
Put back the Netgear, just for fun. My god, the soundstage collapsed, the sound became lean, the details less present….and so on.
The more time I have with the EE1 the more I’m impressed with it. No way I’d remove it. I’m thinking about adding another one or maybe the new CAD device I posted about in another thread.
To get the benefit, you need a GS108E or GS108T switch (not the standard GS108 unmanaged switch) and a low noise power supply (such as the iFi Power X) and then set the switch to low power mode.
Had purchased the EE1 . And plugged on to try out … this is what I had observed— the high and low are cleaner and quieter overall across the spectrum. More micro details been revealed . C clear cable not bad at all…am gonna get either a Sarum T or Music from EE 1 to dCS . I have to admit chord makes better streaming cable .
Plugged on my heindall 2 streaming cable… sound too big for my game room ,although it gives better sound overall.
