@dalmation,
Don’t be put off by some of the replies here, although I reckon that a few of them are really intended to be tongue-in-cheek.
A £14.99 (max £25) TP-Link or Netgear switch from Currys/PC World or eBay or Amazon will do exactly what you need it do do and for absolutely no reduction in sound quality whatsoever.
Should you decide in the future to investigate ‘esoteric’ switches or ethernet cables then by all means experiment with these.
I personally have 2 main streaming systems of reasonable quality (Linn Klimax DS/1 and Sonore microRendu/Mytek Brooklyn DAC+), and I found that switching from a cheap TP-Link consumer switch to an ‘industrial’ Cisco 2960 (2nd Hand) switch made little or no difference to the sound of my systems. I have no desire whatsoever to experiment with more esoteric so called ‘audiophile’ switches.
They may make a slight difference, but they cost an awful lot more and I am pretty sure that their effect will vary greatly from system to system. I suspect from my experience and that of others, that the Linn Klimax DS steamer range seems to be particularly effective in warding off unwanted digital ‘noise’ and so does not benefit a great deal from alternative switches and ethernet cables.
Don’t know about the Nova, but you can experiment later down the line.
Just get yourself a TP-Link or Netgear Gigabit switch for now.
