Camphuw
February 20, 2026, 11:20am
929
NOAA site is more up to date but not as easy to envisage.
Winter Olympics Medals per population. If my Maths are correct, if we were as good as Norway, GB would have 500 medals.
Camphuw
February 23, 2026, 4:26pm
931
A map of Roman London overlaid on a modern map.
This is a map from some time ago getting from the test centre in Walsall back towards home.. childish…I know
And another fascinating and childish map from here in Riyadh…
I can certainly confirm the 170+% in southern Hampshire!
what or where is this and what does it mean?
Martin
@Martin
It’s, erm, a limp joke…
@Elkman70 did say it was childish!
Place is Walsall, West Midlands (not at all relevant to the map pictorial)
Bern12
March 23, 2026, 7:53am
943
I love this map, with all the traditional names. Fantastic.
It’s a stunning map and took quite a while to fine one I liked in perfect condition. It’s the texture and rich print of an original that needs to be appreciated in real life.
I thought I wrote a post about this map and a quick search brought these posts up. Can’t believe it was 5 years ago.
[_0000638 low]
[_0000634 low]
Eventually decided on the frame moulding. Wanted it to look old, but not appear to be at home in a castle. I had many ideas, but settled on this warm, wide, yet delicate moulding. I think it looks great, but might dislike it in 10 years time. Who knows.
This was the first frame I’ve made from scratch using V-nails that professional framers’ use. Initially, I was put off the idea as apparently the machinery is expensive. However, I took a chance on a small hand-…
I’ve learnt a lot about conservation over the past few weeks. To sum up, unless every single part of the framing is of conservation/museum standard (which in pure materials, doesn’t cost that much more than bog-standard stuff), your art will be rapidly deteriorating. This can easily happen within 2-3 years. It’s been a bit depressing opening framed art and seeing some of the damage. If there has been obvious damage, the backing board or rear mount has caused the biggest damage and unfortunately …
Camphuw
March 31, 2026, 12:59pm
945
A variation on an old question.
