As is my custom I turned the radio on (‘qute) before I walked the dog, fed the hens, turned the radio off and walked the dog. On my return the ‘qute displayed “fault 10” … a radio module comms issue
I have rebooted the ‘qute and it seems to be fine … has anyone else had this issue?
I too have had this fault message, which came up a few times after turning my Qute (1) back on. Now that I leave it on, it seems to switch between inputs without issue.
When I contacted Naim, they suggested sending it in for diagnosis as they suggested that it is it a hardware fault, but since it seems to be ok for now, I thought I would save the £330+.
Thanks Maxwell
