Hello this is my first post … I recently fired up my system after it had not been used for a number of years … worked fine but today there was no output from the CDX other than static … checked the connections they were fine … the pre-amp is a 32.5 … tried connecting the cable to another port on the 32.5 but same result … any suggestions would be appreciated
What amp?
Power supply?
“Static” sounds like you probably do have a fault with the CDX, in which case your options are limited, but sending it back to Naim for a service is the best of them, if they still can service a CDX.
Best
