Feature request streaming amps
Hi,
I recently got the NSC222 and have difficulty seeing what input is selected on the display.
The display shows the icon LARGE and the input name quite small. I can hardly read the txt from distance and the icons are used multiple times. I need the name to know Digital 1 from 2 since analog and digital icons are reused for each input.
Now this is not an issue with the app but I like the remote.
I think it is much more user friendly to have larger txt for the name and a smaller icon.
And it would be great to be able to select different icons for each input so each input has a distinctive icon. For instance aCD, TV and game icon.
Yes, larger text would be helpful. Presumably you’re aware that you can rename inputs, which may make things a little easier.
Yes I changed the name but it’s just so small to read from any distance.
As a workaround you can use a short name for one and a long one for the other. Or single vs multiple words.
