Yeah - but this is what ChatGPT says to your response.
I figure I’ll put this and close the discussion out…
Your friend is mostly correct in the theoretical definitions, but they’re glossing over how things behave in real-world audio systems, especially in high-resolution or poorly grounded setups. Let’s dissect it point by point — technically and practically.
Breakdown and Corrections:
“The Ethernet PHY won’t or is unlikely to create common mode noise”
Technically True — but incomplete.
• Ethernet PHYs are differential transmitters/receivers, so they ideally only generate differential-mode signals.
• However, real-world PHYs are not perfect — asymmetries in layout, impedance mismatches, and especially poor PCB design or inadequate power/ground plane isolation can cause leakage into common-mode.
• Additionally, common-mode noise can still ride on the cable shield or twisted-pair reference from external sources like the switch’s power supply, chassis leakage, or even radiated EMI.
So: The PHY isn’t the origin of common-mode, but it doesn’t need to be — the cable is the antenna and the ground path is the loop.
“Common mode is generated by earth leakage currents… from double-insulated products and PSUs”
Correct.
• This is a known issue in SMPS-powered gear, especially Class II (double insulated) devices with floating outputs.
• Leakage currents return via Ethernet shields, USB, SPDIF, etc. — and that’s why ferrites work: they block the return path for that high-frequency common-mode current.
So: Yes, ferrites target exactly this kind of leakage — that’s the practical value.
“Ethernet PHY is likely to generate differential mode noise. A ferrite will have zero effect on this.”
True.
• Ferrites block common-mode currents — they do nothing to differential-mode signals, including data transmission or PHY-internal jitter.
• That’s exactly why Ethernet works fine even with ferrites: the data goes through untouched, but RF garbage riding on both wires together gets choked.
So yes, he’s right here — ferrites aren’t for fixing internal PHY jitter or differential-mode corruption.
“Common mode noise has nothing to do with baseline noise.”
This is where theory diverges from audiophile reality.
• While common-mode noise doesn’t directly corrupt the signal, it can couple into DACs, clocks, or analog stages through ground contamination, power modulation, or capacitive injection.
• This does affect what people hear — especially in sensitive systems — as what they call “baseline noise,” “glare,” or “hash.”
• So while common-mode ≠ signal noise, in poorly isolated systems, common-mode becomes audible through indirect coupling paths.
This is exactly why optical isolation, ground breaking, or ferrite chokes are used — not to clean up the digital signal, but to clean up the garbage that rides along and leaks into analog domains.
“Toslink avoids common-mode, and SPDIF with ferrites is a workaround”
100% correct.
• Toslink galvanically isolates — no electrical connection, so common-mode noise can’t flow.
• Coax SPDIF often carries ground-referenced noise, especially from TVs, cable boxes, or PCs — exactly why people hear hiss or hum when using SPDIF but not Toslink.
• Ferrites on SPDIF work the same way as on Ethernet — they choke off that unwanted current on the shield or outer conductor.
Bottom Line:
• Your friend is correct on how signals are supposed to work in ideal engineering terms.
• But in real-world, high-res audio systems, common-mode noise is pervasive, and it does affect what we hear — through mechanisms that aren’t strictly “signal path” but are ground coupling, analog modulation, and radiated injection.
• That’s why ferrites on Ethernet cables, coax, or USB cables make a difference, even though they don’t touch the digital signal.
So yes: he’s right in theory — but you’re fixing problems that exist in practice. And that’s what matters.
