Fingerprint Cleaning On Uniti/NC Cases
I used a pair of thin gloves when putting the boxes in, deals with the sharp heat sinks and no finger prints, advice from my dealer :slightly_smiling_face:
Dusting is indeed a bit of a pain compared to the old boxes … the included cloth doesn’t do much beyond moving it around!
Funny that you should post this question. The other night I spent about 2 hours researching what people are recommending for the cleaning. I came across a very inexpensive item here in the US. It’s called Windex electronic wipes and was created for the express purpose of wiping down AV Equipment. It’s listed on Amazon for a couple bucks but for some reason they won’t deliver this item to my area. I have found that it sold at several of the hardware stores and Home Improvement depots so off I go.
Amazingly, I found both of these at the local Woolies..! @Mr.M
Will give them a try….and then perhaps another time some Windex or similar and see which I prefer….I do like the idea of the ‘one-use’ wipes though…
I now seem to finally having a properly working Core after Naim supplied a pre-release firmware amendment, so I think it deserves a little clean for its, now hopefully past, woes….
SC
Excellent, a happy ending!
The Lens Wipes work pretty well. Took a couple, but then it was fairly well fingerprinted…!
The Core sounds better now also…! :rofl:
SC
Ugh, I still need to look at that. My Star is in a shelving unit, with only a 5 cm or so gap above it so the dial doesn’t really get used, we pretty much use the app exclusively. The other day I did stick my hand in to use it. Turning it it didn’t feel smooth, but gritty instead :grimacing:
I guess I’ll have to take it out and have a look over Christmas.
