Firmware 4.9.4 not working
Hi all
I have two UnitiQute and one SuperUniti. I had their firmware upgraded to 4.9.4 by my local authorized Naim dealer and after that, Iradio was working perfectly. About three weeks ago, all three unit stopped playing iradio. I did all the moves to restart them to no avail.
Do other Naim owners have the same problem? Anything I can do to resolve this problem?
Did you also try a power off/on the router ?
Yes, 2-3 times and also the Uniti units
Hi Bobby,
is it impossible to browse the radio directory, or a case of that you can browse but nothing plays?
Best
I can browse but nothing plays.
Can you search for a new station, anything will do? Does that play? If so are you aware of the new iRadio settings?
