aldana
September 2, 2020, 7:27am
#1
After upgrading 3.5.0 on my Unity Atom Spotify connect stops working which is a disaster.
Setup:
Unity Atom 3.5.0
iOS Spotify App
MacOS Spotify App
On both apps connecting to Unity Atom hangs, see screenshot
As the only change I did was the upgrade a faulty software on Naim side is highly likely
Anyone else experiencing this problem? Can I rollback to previous version 3.4.0?
Have you done a reset of the Atom?
Have you logged out of your Spotify account then logged back in again?
aldana
September 2, 2020, 10:34am
#3
Thanks, yes I did a factory reset (but firmware for some reason stays the same).
What I haven’t indeed tried, is to Spotify login/logout on my mobile-device and Laptop.
OK, well do try that and let us know.
n-lot
September 2, 2020, 11:03am
#5
After upgrading I’ve had this issue with the Chromecast on my Star, and once it also just disappeared of the network completely. I needed to unplug, and plug back in to fix it. This happened in the first few days, but hasn’t happened since, so touch wood.
aldana
September 10, 2020, 11:50am
#6
After unplugging, login/logout on Spotify on all my devices, things work stable again last 7 days.
Thank you.
system
closed
November 9, 2020, 11:50am
#7
