Firmware v5.4 for NC is now available
Great - thanks for the advice.
Can’t turn USB off though. Wonder why. Maybe @igel has a say in development.
Yes - that is a strange omission.
:grinning_face:
We haven’t been able to turn off USB since the web management interface was disabled.
Perhaps @Paul.B or @110dB might offer some clarification?
ATB, J
It could be a nasty trap, if you disable it and then somebody (else) puts a stick in and wonders, why it’s not recognized.
(Okay, okay, you could make it „show only when something is plugged in“. But I guess USB is amongst the oldest inputs in current firmware and hasn’t been touch in a long while.)
This is getting a bit weird. Still no sign of the update but when I check for updates in the app it just seems too quick, like it isn’t polling a server to see if anything is available. Going in to the configuration page update section it tells me the update can’t be downloaded from the internet. Diagnostics page says everything is connected.
Ah, not having a 222/333 I did not have a look at the announcements. It actually lists all applicable firmware version per product.
So, it’ll be 3.13 then.
Luckily I got there first…
Yes I would agree with that. More analogue/organic. Do you feel the improvement in PRAT was to do with better bass? I need to do some further listening but this is definitely an area that has improved.
Better bass? Can’t tell yet. Bass fuller without boom.
Thanks again. Hadn’t seen this in the Announcements. Will await 3.13.
My NSS333 sounded great before the update but there must be magic Salisbury dust added to this firmware because I continuously stop and say “Wow!” to myself when just playing in the background. I do love my N50 + 333+555PSDR setup a lot! :slight_smile:
Hi Mario, I couldn’t get a definitive answer when I enquired about this today (busy bees), but I have tested it for myself & I’m sorry to say that the issue appears to persist.
:frowning_face_with_open_mouth:
Neil.
Hi Neil, thank you for getting back to me, and especially for physically checking the two units together. Im sure there would be other users that combine new classic and classic components even though most would have a 332.
Both units are current so I do hope it is still something that naim address, I couldn’t stretch to the NDS555 and could not resist the new styling that naim has taken. Combined with the npx300, it is a worthy source for my active DBLs.
Its back to two remotes and a tablet then.
Mario.
Good to hear. Updated this morning before work. Is unplugging/plugging back in or factory reset recommended with this update?
Nope
I found I had to turn on the screen and turn it off again. Otherwise the volume did not show ion the 333 screen when I rotated the 332 volume knob.
If it all working then should be ok. I had a glitch after 333 was updated, a full power down and restart sorted it.
Updated my 222 and looking for http://IP/webclient. Where is the webclient? How to revert to previous version?
