I’m aware it’s not going to perform at it’s best, but is it technically possible to power a NAC 282 from a Flatcap XS for both the audio circuitry and the control circuitry?
So it would serve the usual functions of both a NAPSC and Hi-Cap.
Have searched through connection guides and manuals to no avail.
Power supply specs suggest that Flatcap XS doesn’t have the 18.5v output that the NAPSC would normally provide.
If you have a 282 it should have come with a Napsc, did yours not come with one ?
Also if you have seen some sort of “bodge cable”, any sort of discussion of power supply mod’s is not allowed under forum rules.
Yep, I do understand the rules. OK bodge was probably not the right terminology, it actually looked like a Naim cable with 5 pin DIN flatcap output to the smaller NAPSC connector at the other. I could be wrong though.
I think it is technically possible to use a Flatcap XS in place of two Hicaps. This is considered by the forum to be sub-optimal, but is a possible way forward for you, perhaps on a temporary basis until you can buy a HC (or two).
Thanks for all the responses.
Have now had it confirmed that the 282 (soon to be in the post) will come with a NAPSC.
The NAPSC wasn’t on the listing, just a Flatcap.
So I didn’t go for the Flatcap as it deserves at least a Hi-Cap DR.
Plenty time to hunt down a PSU when the 282 is being serviced.
