I think in your situation I would have considered using the Gaia Carpet Discs with isoAcoustic Gaia for the speakers.
Another recommendation for Herbies Giant Titanium Cone/Spike Decoupling Gliders. I use them under my spiked speakers and rack. Improvement in sound quality and easy to move both speakers and rack if needed.
They also have a 60 day return policy with full refund except for cost of return shipping.
I have a set of those but found them to be incredibly difficult to site and that was on a normal carpet so I dread to think what they’d be like on the sisal! That said I don’t mind trying them.
I have had the Gaia Isolators and Gaia Carpet Discs.
Imho I did not think the Gaia’s made that significant difference as to spikes on granite cutting block on carpet.
I found using the carpet discs to be fiddly when trying to line up with the Gaia Isolators. Also, the carpet disc spikes do not penetrate the carpet to a sufficient depth. ![]()
Everybody is fond of Gaias but they are quite costly. I have laminate floors and I replaced the small “ceramic” pads that went with my Tannoys with larger gliders made of steel+hard plastic (similar to the ones shown above by seakayaker) I bought on Amazon at 27 euro/set of 4. The difference was huge. Maybe because the spikes sit more tightly in the steel cone-shaped holes of the new pads (the old ones had a cup-like shape). Maybe try one of those first?
I guess “costly” is a matter of perspective. My speakers were $16k (retail) and the Gaia II that brought a lot of improvement for them – for the unstable wood floor I have – were about $600. So for 1/26th the cost of the speakers that seems like really pretty big bang for the buck to me.
Of course, it is. The topic starter owns Spendors S6e. So, it will be 1/3 of the price (if I got the price of the speakers right after googling quickly). So, in this context, “costly” is a right word to me. And even in the context of my 3K Tannoys… ![]()
Ceraball Universal by Finite Elemente are a less costly and perhaps more visually unobtrusive way to get some decoupling.
Just ordered 2 granite slabs 20mm is the thickest I could get. Is it best just to sit them directly on the laminate?
Amazon sells some black granite chopping boards quite cheap that work a treat also under speakers
Yes I looked at those but they appear to be quite thin. The ones I’ve ordered are direct from a local fireplace manufacturer and from off cuts I saw a sample and they should be perfect and only being charged £30 for the pair. My only doubt is if I sit them directly onto the laminate or stick something onto the underside. Will this effect sq vibration etc.
Everything touching anywhere causes issues.
I would try them on the floor with nothing on them and if they click or rock at all I would put rubber pips on them.
But every different material will have a different effect to sound transfer but stability is most important. ![]()
Felt might be a good option.
I stuck 2 pieces of selfadhesive feltmats under each tile. Works perfect,no vibration and speakers can easily be moved by sliding them to the best position for sound image.
Yep. Sticky felt thingys you put under furniture. That’s all you need. And it makes moving speakers easy.
