Hi guys ,
what do you think about the Aria 926 ? Any feedback with Naim ?
( system 272+200 )
Hi guys ,
( system 272+200 )
Work well with Naim for the price. Lots of presence and scale and a big sound for the money. Can sound a little harsh and care with positioning helps. In their price range I found them hard to beat. Should have addedz they were voiced to work with Naim
Absolutely brilliant! They work beautifully and when I did a sound test, they (In my opinion) were significantly better than anything in the price range. They are fantastic with my system. The sound stage and separation is fantastic. Big recommendation.
Neil…Wich system do you have ?
Aria 926 has been a fantastic speaker in my experience paired with SuperUniti. I think they punch well above their price and do sound v rich and full bodied.
I have the Focal Aria 936 and I think they are fantastic, look great and are well built. They are the larger brother to the 926 which I would imagine would sound fantastic too!
I’ve got a NDX2, NAC 202 and NAP 200 DR. However when I originally got the speakers I had an ND5 XS2 and and older pre/power amp combination from the xs range. The speakers worked just as well with both and I was told when I bought them that they were easily good enough to cope with a higher level 286 level set up.
