Does anybody know if the focal sopra 2 come with floor protector discs for wood floors.
Mine did not come, now using gaia3, a nice difference, they are rubber vacuum type
Or use naim chips ?
Yes mine did here in US.Im on carpet so haven’t used
How are you getting on with your sopra 2.?
Use Herbie gliders- I replaced my Naim chips with them.
The Sopra’s are big and heavy. On the gliders they will sound great and if u have to move speakers to make adjustments they slide and won’t damage your floors (as Chips would).
I use them on my Kudos Titans which weigh more than the Sopra’s.
Yes they do… Mine came with spikes and round flat protectors
@Hawkmoon I now actually have the Sopra 3 but had the Sopra 2 for about 6 months and really enjoyed them. I have a rather large room and was able to “trade up” to the 3s when they became available without loss. They are very similar with a little more low end extension on the 3s.Overall I think these speakers are great for example can’t convince myself that Wilson Sashas are better on demo although never compared in my own room. Interested in the Kudos Titans based on the reviews on this forum though.
Would the sopra 3 what colour did you get
White
Cool the storm troopers
